miter-loc on ipe
manchuian | Posted in Construction Techniques on June 29, 2010 06:47am
Hello all ,
    I have a railing job that call for solid ipe 6×6  posts ,I generally use a 4×4 and “wrap” in the wood of choice . I have used  (with sucess) soild clear cedar that was dried . Also more commonly available back when . The question is ,is the ipe going to be too hard to mill a miter loc on 5/4 stock ? I don’t own a shaper but do have a 3 1/4  porter cable set up on my Jet table saw combo .
 On the off chance that I could locate -(I’m in westchester county ny ) a 6×6 would it end up checking even if all end grain was sealed .
                         Thank you for any advice ,Chris
    hammer1 | Jun 30, 2010 07:56am | #1
    Ipe is just a lot harder than a soft wood like cedar. It will dull your bits more quickly and you'll need to make smaller, incremental cuts.
    Jeff_Clarke | Jul 01, 2010 06:41am | #2
    Chris - assuming that this is an exterior railing skip the miters entirely - time and experience have shown that many miters exposed to weather conditions eventually open up.   Use a biscuit joiner and attach boards with butt joints.    I've never seen a 6x6 Ipe post and if I did I sure wouldn't want to cut it.
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
