I have a deck that will be in the way of my inground pool when construction starts. My question is; can I modify my deck by shortening the length by around 4′? In the picture it would be in the blue circle area.
It depends on how the deck is supported. what framing is where.
As Uncle Mike says, depends on the framing and support. Since the decking is running parallel to the house, I think the framing is coming out. So, in theory, you could pull up the decking about where you want to shorten it, cut and reframe at that point. If you're careful, you might be able t reuse the rim boards, and railing. You would need new piers for support, so you need space to dig a hole for that.
However, unless you're hand digging for the pool, I think the deck may be in the way with excavating for the hole.
good luck
UncleMike and firedude thanks for the replies!
Are you contemplating a DIY project, or hiring a contractor to do the work?
Come back if you want to explore more and dig into a project.
DIY
dig in - swimming pool project ....lol
I don't see any problems with your plan. the joist run from the house to the outside edge so shorting the deck would mean either removing some decking and joists or cutting the ends back. I can't tell exactly which direction you're going but in either case, I don't see any problems. Obviously, you may need to add some support.
I plan on adding supports...thanks!!
Start by pulling up a few deck boards (will need to figure out if they are screwed in. some have torx head screws, others have Phillips heads....)
The pattern of the nails will spell out where your joists are. How the joists are supported will dictate how to proceed with the trim job.
