Mold resistant or regular drywall?
robbyve | Posted in Construction Techniques on December 25, 2022 11:46pm
 Hello guys, again another question.
I’m building a 12×15 office with a small bathroom inside (no shower, no bathtub). I will have a sink not only in the bathroom but also in the office for practical reasons. Do you think I need to use mold proof drywall sheets in the bathroom and also on the sink side in the office? Thank you for your eventual suggestions.
  1. Eschreiber1990 | Dec 26, 2022 11:12pm | #1
    With the addition of the Moisture resistant paper, its probably not worth going back and forth. I would use the green board since you may have potential moisture. Most codes will require it in that instance and the cost is not a huge difference.
    1. robbyve | Dec 30, 2022 01:19am | #3
      Thank you very much! I appreciated your suggestion. Since I will have a sink inside the office itself and not only in the bathroom. I wonder if I have to do the whole office with green sheets. I have to find out the codes.
  2. user-1149528930 | Dec 27, 2022 01:17pm | #2
    I might even step up to glass Matt product USG makes several depending on whether you want x rating and impact resistance. You do have to skim coat the entire surface prior to painting and it is more, but it’s the most mositure model resistant-you canneven leave it outside as a facade. Commercial builders know all about and freely use thsi type of product .
  3. robbyve | Jan 02, 2023 10:19pm | #4
    Thank you very much for your suggestions. I will follow for sure.
  4. calvin | Jan 03, 2023 05:54am | #5
    Rob,
    The post you replied to has been removed because of the spam link included.
