More than two 3 way switches? Possible?
![](https://secure.gravatar.com/avatar/14f98520bfb1a5c2af5edff4b7b87b15?s=52&d=https%3A%2F%2Fimages.finehomebuilding.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
We currently have a light at the top of our stairs that is controlled by a 3 way switch, one at the bottom, one at the top.
I would like to put in a second light, at the other end of the hall from the current light, that is also on the same circuit. I’d like to also put that one on the same 3 way switch, so that ideally, all 3 switches could turn on and off both lights. Is this possible?
Yes you can do that. But any switches after the first on is are 4-way switches.
This shows the logic of the 3/4 way switches.
http://www.selfhelpandmore.com/switchoutlet/4way/
And the links show all of the way that then can bewired.
The additional light is a separate issue. In general the simpilest way is to run a cable from the first light to the new light and parallel the connections at the first light.
