More weight on roof structure?
nomorecoffee | Posted in Construction Techniques on February 18, 2020 05:05pm
I have a plain gable roof built in the early 50’s with 2×6 douglas fir rafters.  2×4 stud walls first floor.  No dormers, no skylights.  I want to insulate it, which means putting up 1/4″ plywood as baffles in rafter bays, building out 2″ on the underside with ripped 2-by’s perpendicular to the rafters at 16″ intervals, and filling the space with mineral wool.  Is the added weight of all of this on the existing structure something I should be concerned about?
  1. florida | Feb 18, 2020 05:15pm | #1
    No, not at all but have you looked at foam? Much faster and easier and will make your house stiffer. But, is there a reason you're insulating the roof instead of over the joists? Typically insulation goes on the ceiling.
  2. WISteve | Feb 18, 2020 05:39pm | #2
    no.
  3. nomorecoffee | Feb 19, 2020 07:02am | #3
    Thanks. Forgot to mention, roofers added 1/2" plywood over the original 1-by roof sheathing so it seemed to be adding up.
    I looked at foam but I want a vented roof and there's a lot of carpenter ants around here. The attic is finished, otherwise, yes, I'd be stuffing the joist rafters (and I am where I can). I have more detail in an energy/insulation/heating post, this question seemed a better fit for this category.
  4. oldhand | Feb 19, 2020 11:57am | #4
    I bet if you looked up the weights of your building materials you want to add and figure out the weight of a square foot of it combined it wouldn't be much.
  5. user-3976312 | Feb 27, 2020 11:23pm | #5
    If you plan to make it a finished ceiling after insulation you might want to consider the total weight and check it under dead load on a span table. Also consider snow load, depending on your climate. Insulating the roof will mean more snow building up.
    1. nomorecoffee | Mar 14, 2020 08:08pm | #6
      Had a question about using span tables and snow load but moving that into its own post under code.
Outdoor Lighting
