Mortar for Parging
Mikeman | Posted in Construction Techniques on September 27, 2012 11:15am
I have an older home with a stone and mortar foundation.  It appears to be limestone, but I am not a geologist.  I purchased the house about 18 months ago.  My plan is to reparge the entire interior wall surface.
The foundation appears to be in decent shape – no loose stones or cracks – but the parging is all over the map – it has probably been done 5 times over the past 98 years.  The wall/floor joint is the only area where moisture is visible after a rainy period – never any standing water though, but effervescence is present in a few areas.
After doing a considerable amount of research I planto use either a type N or a homemade type O (no one seems to sell a premade one) by adding 1 part type S hyrdrated lime by volume to the off the shelf Type N cement mortar and of course sand. Since I am working on the inside on a natural stone I am not concerned with excessive compressive strength, and since the existing mortar is in relatively good shape (i.e., not a repointing job), will not be exposed to the elements or any freeze-thaw action, my primary concern is vapour permeance and then durability.
Will a type N (1:1:6) or type 0 (1:2:9) (c:l:s) mortar have enough permeance to avoid the often discussed problem of trapping water in the wall when the original mortar appears to be a pre-portland mix (i.e., lime and sand only).
The other side of the wall is (unseen) but likely not dampproofed.
Thanks in advance for any help.
I have talked to a couple masons on different sites and they look at me like I have two heads when I mention lime mortar; both have recommended type s with an admixture to increase adhesion. Is it possible that given the sheltered relatively good shape, that something more durable like a portland sand mortar would be good enough?
sorry for all the long post
  1. gfretwell | Sep 27, 2012 09:20pm | #1
    I have never heard of anyone using anything other than type S or old school guys just mixing sand and portland.
    I would paint link on the wall and use type S.
  2. calvin | Sep 27, 2012 09:43pm | #2
    25 yrs ago.......
    parged this homes foundation from plate to footer with type S.  I did rich'n it with more mortar for stick.  Important thing, keep the masonry damp so it doesn't suck the water out of the parg too quickly.  The bond will be weak.  I applied over block with 2 coat if I remember that far back.  Over stone?  no idea.
    How's that for no real advice?
