Mortar for setting fixtures?
xxPaulCPxx | Posted in General Discussion on August 10, 2007 08:24am
I’m getting nearer to putting in my new Hydrosystems spa/tub.  3 Wall install on slab.
The instructions say to set it into a bed of slow setting mortar and to leave it to set overnight.  Making a supply sweep through HD last night, I seemed to find bags of mortar that were in competition to set the fastest!  It looks like I can get only and hour of setting time out of those bags.  They also offered retarders in packets – 4 packets to a bag max could add up to 2 more hours to the setting time.
Is this what I should use, or am I on the wrong track here?
I recall someone mentioned a gypsum product from USG that was ment for setting tubs and toilets, but I couldn’t find it myself on their site.
Also a CRX fanatic!
Oh, good Lord, no. But I can give him two dollars and an assault rifle.
  1. JTC1 | Aug 10, 2007 09:01pm | #1
    Is the intended use of the mortar to make a "bed" under the FG spa / tub?
    If yes, just use any of the Quick Crete, or similar, bag mix, mortars.
    I usually make a little dam, out of scrap or furring, around the perimeter of the desired "pad", dump in the mortar, cover with poly and set the tub.
    The poly serves as a release barrier - makes it easy to remove the tub in xx years. Poly does not have to be fancy - even an old dry cleaning bag will work.
     Why do I always look out for the next guy?? -- oh yeah, it might be me!
    Mortar underneath of a FG tub makes a world of difference - nice and solid!
    Jim
      xxPaulCPxx | Aug 10, 2007 10:30pm | #2
      OK, so it appears that setting in "an hour" vs. overnight isn't a dealbreaker on these.  Of couse it is important to bed it down enough to be resting on its lip support while the cure happens.
      I was thinking about that plastic release too... usually because I too am the next guy... over and over again as I go back to correct a mistake or remember something that needed to happen BEFORE I set that dang thing in there :)Rebuilding my home in Cypress, CA
      Also a CRX fanatic!
      1. Geoffrey | Aug 10, 2007 10:56pm | #3
        Paul,
         Check with the spa/tub manufacturer as to what they consider "slow setting".
        The reason they want slow setting is because of the heat generated during curing, faster setting mixes may in-fact generate enough heat to possibly damage the fiberglass.
        I would do the plastic as a release as well, but I usually use 6-mil poly on the subfloor, then pour the mix on that, then use a real thin plastic like painters drop cloths (1 mil ) on the top of the mix, it makes it easier for the mix to "flow" into the contour of the underside of the tub/spa without leaving any air pockets or voids, such as you might get with a heavier gauge plastic.
           I've also had success with using plaster mixes instead of mortar.
        Geoff
    EricPaulson | Aug 11, 2007 12:04am | #4
    You want to use Structolite.
    Perlited gypsum mortar
    [email protected]
  3. Jer | Aug 11, 2007 03:15pm | #5
    Eric is right. Structolite is the thing. Very strong and very light and has body to work with. It's what I've always used and seen used.
  4. IdahoDon | Aug 11, 2007 10:39pm | #6
    Just about any mortar will work great just don't mix it too thin.
    This is a perfect place to use up partial bags of thinset, bag concrete, mortar, floor leveler, cement and sand.  Mix em all up in just about any combination and you'll never have a problem since the compressive strength needed is so darn low.
    If you want a release just spray the underside with a little pam or rub paste wax on it, but no reason plastic won't work just as well.
