Mortar mix question
DanT | Posted in Construction Techniques on May 12, 2006 03:13am
In a building I have recently aquired there is a half a skid of portland cement.  Good condition too.  The only masonary work we do is mixing up a dry mix of pre mixed mortar to put under a shower base or bath tub.
I would like to use this cement so I looked up mortar mixes on google and the all included hydrated lime.  What does the lime do?  Do I need it for what I am doing or can I just mix portland and sand?  If I need the lime I will do so but frankly I am just trying to keep this simple and have the least amount possible of open bags of dusty material  laying around.  Thanks.  DanT
    bobl | May 12, 2006 03:34pm | #1
    lime makes it sticky
    bobl          Volo, non valeo
    Baloney detecter
  2. dedubya | May 12, 2006 03:50pm | #2
    the lime is to make mortar mix you add it to make the mortar workable-stickey
    and to add board life,for what you are doing, half a bag of portland to
    12 shovelfuls of sand makes a great grouting material for big voids.
     have ever wondered why concrete will not adhear well to concrete,but
    plaster-mortar-drywall compound will? its because of the lime in it.
    when you take another look at that portlandand if you notice the bags
    appearing hard but dry, try rolling it around on the pallet and fluffing it
    up as the longer bags of cement sit around it developes packhouse pack
    all the air leaves the bags . at 7 dollars plus change for a bag it will pay
    you to use it. IF everbody knew the amount of human sweat it takes
    to make a ton of that stuff people wouldnt throw it away quite so easily.DW
    1. DanT | May 13, 2006 01:25pm | #3
      Thanks for the information.  It will be a big help now and in the future!  DanT
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
