Mortar Type For Concrete Window Sill On Brick Wall
narnal | Posted in General Discussion on March 12, 2021 08:59pm
Hi everyone. I am enclosing a porch on my FL home that was built in 1940. It has double wythe brick walls. Attached is a photo for reference.
I plan on replacing the brick window sills with precast concrete sills to help with water resistance and to provide a better mounting surface for impact windows. The sill installation instructions specify a Type S mortar bed underneath the sill, but this is assuming the typical CMU install. Would it be OK to use Type S mortar on top of the bricks? Or should I use Type N or something else?
Thanks,
Nick
  1. kbentley57 | Mar 13, 2021 11:37am | #1
    Nick,
    Type N or S is perfectly fine for this application. The load there is minimal compared to the strength of either. If it calls for type S, I'd use type S.
    Kyle
      narnal | Mar 13, 2021 12:02pm | #2
      Thanks for the response Kyle. I have heard that you should not mix a stronger mortar with the existing mortar, which I am assuming is N or softer since it is 1940's brick. Does that rule not matter in this case, since I will be laying a fresh bed joint?
  2. kbentley57 | Mar 14, 2021 10:49pm | #3
    Nick,
    Generally I think that applies to repointing, or patching in bricks where some have been removed. If this is a fresh bed that's on top of the existing, I doubt you'll run into any issues.
      narnal | Mar 15, 2021 06:06am | #4
      Great. Thanks Kyle!
