DW would like a motion-activated ceiling light in her new pantry so she can go in hands full and have light. All we see locally are exterior lights that work only in night time darkness. Ceiling is wired. For several reasons, the jamb-mounted pressure switch will not do. Looking for suggestions, with advance thanks to those who have some.
If you have a wall switch in the pantry now or can mount a box there you could get on of the motion detector switches used in some commercial restrooms. Fit a std. box.
Mike
I installed a motion switch in the basemnet. It worked great. I have not seen a ceiling mounted interior motion switch, but you can search the electrical parts web sites and find all kinds of odd stuff. I just bought 20 amp pediatrican/hospital tamper proof receptical.
I don't know what kind/size of pantry this is.
But probably a good option would be a wall mount unit that "scans" the door so that you would cross the path entering.
But yes they do make ceiling mount sensors.
http://www.sensorswitch.com/o/prodapp5.htm
http://www.sensorswitch.com/o/linevoltagesensors.htm
http://www.sensorswitch.com/o/wallswitches.htm
You can also get the sensor that is used on outdoor units by itself. I think that I saw them on ebay.
if you can find those you can get basic outdoor motion sensor flood light and remove the sensor (it is all self contained).
Then mount it on a metal cover plate and install it in the ceiling or top of the all oposite the door.
the advantage of that unit is it can be aimed.
Another company that sells occupancy sensors is http://www.wattstopper.com/
One of my customers has motion activated lights plugged into the hall receptacles. I'm not sure what kind they are, but they look like an oversized nightlight. They aren't bright - just enough light to avoid tripping over stuff.
Another customer has a motion detector/light switch just inside the door from the garage. It turns on all of her hall lights as soon as the door is opened.
Any electrical supply should have a motion sensor switch. Easy stuff. We use them in all closets.
Our electrician uses an alarm contact set with a relay for this application. It's way cleaner than the door jamb switch.
