mounting blinds into masonary
jerseyjeff | Posted in General Discussion on April 18, 2007 09:48am
My sister has a place in NYC and wants to put up mini blinds (the place rocks,  but has a lovely view of the midtown tunnel)   It is a concrete and steel building and I am looking for the best way (and hopefully easiest to secure the blinds to the concrete….  I am thinking tapcon/caliburn screws are overkill,  and lead shields seem overkill too,  but I almost certain regular screws will blow out.  Oh,  I think that a Powder Actuated Fastener gun will probably end up with an arrest warrant too…   I have a hammer drill (corded and cordless)  and am pondering what to do…
jmmmm
    MrSQL | Apr 18, 2007 10:59pm | #1
    Old fashioned way (I've used it several times) was to drill out oversized holes and then hamer in a wooden "suppository" [any old wood / wood scraps will do; they will conform to the hole].  Then you just screw into the wood.
    1. Norman | Apr 18, 2007 11:01pm | #2
      The Tapcons are a whole lot easier, the only extra effort is drilling the hole for the screw. Short of glueing them into place, I can't see anything easier than the Tapcons.
    2. jerseyjeff | Apr 19, 2007 02:47am | #3
      I think i might go with the small expanding plastic anchors,  the blinds arent going to be that heavy,  so it should be ok...jmmmm
      1. Mark | Apr 19, 2007 03:14am | #4
        I've done that a bizillion times.  It works magnificently. Just use a 1/4" tapcon drill bit to drill the hole and then pound the plastic anchor into the hole.   I usually use short drywall screws , but I imagine you could probably just use the actual screws that came with the blinds." If I were a carpenter"
        1. jerseyjeff | Apr 19, 2007 03:40am | #5
          Now I am thinking that I am going to use a piece of 90 degree pvc to hook a vacuum to so I can catch all of the debris so I make very little mess...  I am hoping that this will be a grand success..
          I am planning on drilling through the right angle of the pvc.
          we will see....
           jmmmm
