Mounting sliding drawers under workbench
79136.1 | |
Take a look at the photo which I attached (I hope) and let me know if there is a way to mount my drawers to the underside of the workbench. If there were cabinets then I would use standard drawer sliders, but there isn’t anything to attach the sliders to. Yes, I’m a dumbass for not figuring it out before I bought the drawers. Thanks in advance for the help. Frank |
since the picture is invisable... how about a WAG...
there are under mount glides to fix that problem...
BTW ya hang yur drawers out on the line or run 'em thru the dryer...
KEYBOARD SLIDE 12" 75#
3/4 TRAVEL 16" DRAWER WIDTH
HOLD OUT DETENT LEVER STEEL
BALL BEARINGS 2109 12
KEYBOARD SLIDE 14" 75#
HOLD OUT DETENT DISCONNECT
LEVER STEEL BALL BEARINGS
2109 14
KEYBOARD SLIDE 16" 75#
3/4"TRAVEL 16"DRAWER WIDTH
2109 16
KEYBOARD SLIDE 18" 75#
3/4" TRAVEL DRAWER WIDTH
HOLD-OUT DETENT DISCONNECT
2109 18
KEYBOARD SLIDE 20" 75#
3/4 TRAVEL HOLD-OUT DETENT
STEEL BALL BEARINGS
2109 20
KEYBOARD SLIDE 22" 75#
2109 22
WOW!!! What a Ride!
Edited 9/25/2006 8:07 am by IMERC
I put some drawers under my workbench with drawer slides that mount to the underside of it. Don't know the specific brand, but they're out there.
You could also fasten a 2X6 (or other lumber) in a vertical position between each drawer and put drawer slides on the sides of them.
I see no photo, but there is hardware available to hang from a countertop. Grass, blum, KV etc.
Or, hang "sides" down from the top and use that to mount hardware.
Or build boxes to house the drawers, hang those from the top.
Quittin' Time
I put pairs of vertical 2x4s under my benches, and have literally dozens of drawers - standard 28" full-extension side-mount slides.
Edited 9/25/2006 8:54 am by McDesign
Beautiful!!!! How about pictures of the rest of your shop?
Enjoying the threads about your other work too.
Thanks,
oldfred
Thanks! Here are some more from that day - shop was kind of a wreck - (sorry for the hijack, OP, but it's still sorta' on topic!)
Forest,Nice shop. Is that a gas unit heater in the last pic?How many steps up to that door?Do you have an overhead/grade entrance?It is great to see where all of the fine work you do is fabricated..
I do remember the pic of the second story balustrade surrounding your radial saw sort of like a playpen.Chucklive, work, build, ...better with wood
The box on the wall is a circulating air cleaner - Delta. Never gets cold enough here that a 110-V electric heater won't heat it - it's well insulated .
The wood shop is walk-in on the West side; sides and back are 3-4' below grade. The (5) steps go up that grade East to the garage / metal shop / storage area, a 22' x 14' slab on grade bldg - it has a roll up door on the North end. It also has a covered porch and a nice door, porch swing and porch light on the street side, so everything hides behind what looks like a tiny cottage
It's kind of an accretion of growth as my needs for space increased!
Attached on the West side is 20' x 30' pole barn for wood storage and to park the camper.
Thanks for posting the pics. OK to e-mail you with some questions on size, vac system, etc.?
For anyone interested in more shop views, check out http://www.shoptours.org/
And now, back to our original program.......
All posters,
Thanks for the suggestions. I was thinking of hanging 2x6's under the workbench, but I figured there has to be other ways and you all showed them to me. Now if I can figure out why I attached a photo to my original posting and it didn't show up. Anybody had the same issue?
Frank
Sure!
