mounting undermount sink in marble
ckorto | Posted in Construction Techniques on June 18, 2008 08:24am
I mounted a tiny 12″ x 15″ undermount sink in a bathroom vanity today per the marble companies instructions.  PL Premium and used some 2x’s and threaded rod to sandwich it and let it set for 24 hours.  .  Seems solid as a rock.
My question is this, I’m used to setting them in 1 1/8″ granite with anchors.  This is only 3/4″ marble so I didn’t want any mounting plugs drilled into my top.  Is the adhesive enough or should I install some rails underneath (not much access).  Like I said, it’s tiny, so water weight won’t be much of an issue.
Thanks everyone, Chuck
  1. cliffy | Jun 18, 2008 04:15pm | #1
    I recently had a granite guy install a sink in my own basement.  He has been doing granite for over 20 years. He installed the sink similar to your way but used silicone instead of PL Premium.  I think you're safe.
    Have a good day
    CLiffy
