Moving a furnace..
frenchy | Posted in Energy, Heating & Insulation on May 30, 2006 04:45am
 I need to move my forced air furnace, don’t worry about the ducting most of that is removed already and the rest will be moved in a month.  My concern is about venting..
  It’s one of those High efficency furnaces with seperate fresh air intake and exhaust made out of PVC.  Right now the furnace is two feet from an outside wall. when it’s moved it will be 20 feet.  If it helps I can slant the exhaust up over 15 inches maybe more, right now it doesn’t slant any that I can see.
  1. DanH | May 30, 2006 05:00pm | #1
    Doable. Probably best if you check the mfgr's specs to be sure the distance is OK, but should be. Be sure to use flu-listed pipe, not just plastic drain pipe, and the proper solvent. Pipe needs to be slightly sloped so that condensation will drain either back into the furnace or to the outside. (Back is better if you live in the Frozen North -- reduces the chance of an ice block at the exit.)
    1. frenchy | May 31, 2006 03:31am | #2
      DanH,
       Thanks, I'll call the gas company who sold me this turkeyand see if they still have specs for it,  I mean it's at least 7 years old so who knows...
Old House Air-Sealing Basics
