Moving a gas/lp range
PatchogPhil | Posted in General Discussion on November 13, 2007 07:30am
I want to move my propane gas range.    The current feed pipe is soft copper with a shut off valve,  which comes out of the wall at the floor.  It is about 3 feet from a corner of the kitchen.  I’d like to locate the range 4 feet from the same corner in the other direction.
The kitchen is over a VERY shallow crawl space and 30 feet of belly “slithering” to get to the location;  not easy to maneuver down there.  So I’d prefer to make the connection above the floor,  below or behind the base cabinets.
I can probably move the copper line to exit at the corner,  working from the kitchen rather than crawling below (behind stove/corner cabinet is access panel to bathtub plumbing on other side of the wet wall).
What’s the longest gas connector flex-pipe I can use  AFTER the valve to the range?
I know that the shutoff valve needs to be accessible,  and is best directly behind the range.  Can I extend the gas line from the existing shutoff valve (moved to the exact room corner) and install a second shutoff right at the new range location?
  1. PatchogPhil | Nov 14, 2007 07:05am | #1
    .......anyone?   ......anyone?    ........   Buehler?..........  Buehler?
  2. Dave45 | Nov 14, 2007 08:27am | #2
    You would need to ask your local building department about routing the gas line like you're describing.  Only they can tell you if it's ok in your area.
    I've also been hearing that our inspectors want the gas valve in a cabinet adjacent to the stove instead of behind the stove.  Apparently, in an emergency, it's easier to open a cabinet (or remove the drawers) than to pull out the stove.
    1. PatchogPhil | Nov 14, 2007 08:38am | #3
      That's not a bad idea.  But if you don't know the shutoff is inside a cabinet,  that might cause some confusion and/or delay when someone does try to move the stove to get to the shutoff in an emergency.
      Thanks for replying.
      1. Dave45 | Nov 14, 2007 05:35pm | #7
        Yeah, that was a new one for me, too - I've always put the gas line behind the stove.
        I'm designing a kitchen right now and was talking to the builder about the locations for the gas, plumbing, etc. so he can do the rough in.  He's the one who told me about the gas coming up in the back of a cabinet.  Apparently, firefighters are being trained to look in cabinets for the gas shutoff.
        1. dovetail97128 | Nov 14, 2007 06:51pm | #8
          I just finished one with only 4 1/2" of clearance at the bottom for valve and plug. It was a 6 burner gas/electric combo. Back of unit was flush and meant to go against the wall.
          Instructions showed the plug and valve cold be located in adjoining cabinetry.
  3. dovetail97128 | Nov 14, 2007 08:39am | #4
    Disclaimer: I am not a certified plumber of gas guy.
    Just have messed with these a fair amount over the years.
    I believe that you can "couple" onto your existing line and move the valve to behind the new range location. Should be relatively easy and standard fittings.
    I have purchased flax for gas lines in up to 60" lengths.
    You really want the shut off/connection to flex directly behind or under the range is possible.
    I have always found my local propane dealer to be the best source of info and codes. They often install ranges themselves and have the needed parts.
    1. PatchogPhil | Nov 14, 2007 09:29am | #5
      You must have been reading my mind....  I had the same thought a few hours ago.  I have a tank to refill,  so I'll be paying a visit to my propane dealer.
      I was just hoping someone here would have some answers while my mind races with the stove relocation plans.
      1. dovetail97128 | Nov 14, 2007 09:35am | #6
        Just paying back the help I receive here.
