moving registers/grills for a renovation
I need to move 3 registers for a kitchen renovation. The supply is being moved from a wall grill to under a toe kick. I assume this won’t affect balence too much. I also need to move a supply from a low wall positon to the floor. Will a floor register in basically the same location have much of an effect? —thnkas
Should not be a problem. Homes are not so precisely balanced that the small changes you describe would have any noticeable effect.
