Mud set for shower pan
dedhed | Posted in General Discussion on May 1, 2006 01:34am
I am a finish carpenter and was smart enough to have a builder bring my addition up to finish plaster, but not smart enough to sub out the tile. Already have a copper pan set for a shower.What should I use for a mud set for the tile?
    BarryE | May 01, 2006 01:40am | #1
    Try here:
    http://www.johnbridge.com/vbulletin/index.php?
    check out the library there for articles. might also look into ditra
    Barry E-Remodeler
  2. davidmeiland | May 01, 2006 06:39am | #2
    Is it absolutely too late to sub out the shower? Unless you want to take on a fairly detailed project that will require a lot of research, a lot of time-consuming careful work, and some new skills, I'd take a pass. I've done showers and will probably do more, but only if I can't find someone more experienced to do them. In fact, I recently committed to two as part of a project and am scrambling to find a tilesetter for them.
    The copper pan is interesting. Is it somehow mated to the drain so as to be watertight? Does it have a slope to the drain or is it just sitting level on the subfloor? If it's not mated and it's level, it's probably gonna hafta come out.
