This fox came into the back yard, killed two half grown wild rabbits, collected them and headed for the den.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
another working stiff trying to keep the kids fed!
"...craftsmanship is first & foremost an expression of the human spirit." - P. Korn
bakersfieldremodel.com
Send her over here. We've got lots of rabbits. And ground squirrels.
Time is the coin of your life. It is the only coin you have, and only you can determine how it will be spent. Be careful lest you let other people spend it for you.
-- Carl Sandburg
"God provides for the Lion,
But the Fox provides for himself."
Wm. Blake
