Stan,
Interesting how you remove the temp 2×4 wall in sections as you install the treads/risers. Makes sense, just never thought it through.
Stan,
Listeners write in about continuing education, minisplit heat pumps, compact home shops, and building science.
nice.
are they building alot of new properties near you??
Kostello: Its been going crazy around here since 1987.
must be a good proportion of higher end homes judging by the staircases you build
kostello: Almost all my stairs are in homes I will never be able to afford.
Nice, Stan.
Do you bend your stringers from solid stock? Or laminate resawn pieces to make the stringer? Or what?
Do you route the mortises for treads and risers before bending the stringers? Are both sides of the tread mortise the same? Seems like the outside must be wider, like on winder stairs only not as dramatic - is that accurate?
Jim: I laminate my stringers. Then I route the mortises for the treads and risers.
The run of the outside stringer is longer than the inside stringer.
boy do i knowthat feeling!!!!
Stan, I love to see pics of your stuff, quite inspiring. I see your bottom plates laid out on paper. Is that a computer printout of the radius stiched together?
And, I've always wondered how you get an actual radius. Does the builder tell what it's supposed to be from the the plans, or do you have some way of getting a field measurment? Don't worry, we can fix that later!
bucksnort: I basically work with what space is given me...changing it if the walking line run is not correct.
The layout in the shop is just done with a tape measure and stapling down rips of posterboard. I just build a full scale two dimension plan of the stairway on the floor...and then build vertically for the Z axis.
In astairb the picture shows pocket screws into the tread at the top and screws into the back of the lower tread . Doesn't that set you up for cracking the riser?
Don: I have never had a problem with this method of attaching the riser to the bottom of the treads with the pocket screws..or to the back of the treads with screws. The joints are glued as well...its very strong.
Stan I love your posts but I was thinking mebbe you could have a couple of murals of stairways painted on the back walls of your shop while yer out flying.... :~)
how big of a radius do you supply too?
also curious what's the longest distance from home base you've built stairs for?
Cag: The largest radius I have done was if I recall correctly..240 plus inches.
The farthest I have gone is 130 miles. 90% of my work is in the shop...the other 10% is in the field installing. For me...that is an ideal ratio as I love the shop work..but its nice to break out and go install a stair system.
In "astairb" is look like the inner curve gets "exact slots" and pocket screws, while the outer gets wedge slots and wedges. Why is that?
Awesome work, by the way. Love your posts. Looks like it's gonna be a good year 'eh?
-Jim
Edited 4/25/2004 7:11 am ET by Jim
Stanley
You shoulda called your stair compant, "Stairway To Heaven".
Great work as usual.
Be well bro
andy
My life is my passion!
