The other day I was using my air compressor. It died. So I checked the outlets for power…good, pulled off the switch cover on the compressor….good, , I take a little sand paper clean the contacts in the switch…not good dont start ..now Im bummed, so while Im putting the cver back on the switch and thinking man this emglo is still pretty new what a bummer, I some little white writing on the housing that read ” motor reset switch. pressed it man it fired up! after all that well you ever see the cartoon where the guys head changes in to a donkeys and goes heee haawww!
This spray-foam sealant from Great Stuff offers mess-free, 6-in. coverage.
The other day I was using my air compressor. It died. So I checked the outlets for power...good, pulled off the switch cover on the compressor....good, , I take a little sand paper clean the contacts in the switch...not good dont start ..now Im bummed, so while Im putting the cver back on the switch and thinking man this emglo is still pretty new what a bummer, I some little white writing on the housing that read " motor reset switch. pressed it man it fired up! after all that well you ever see the cartoon where the guys head changes in to a donkeys and goes heee haawww!
