My first stairway
Hokuto | Posted in Photo Gallery on August 20, 2011 11:42am
Here’s a link to a slideshow of the building process for my DIY deck stairs; I had to remove the original stairway last year as part of the residing job I was doing, and since the veranda rim joist had suffered dry rot due to improper original flashing. I used PT 2x12s and 2x6s for the stringers and treads. The biggest problem was the 10° skew the stairs had to take from the veranda to remain on the deck. That threw off the alignment of the treads, forcing me to cut out small divots in each tread where it meets the stringer; a bit tedious, but it worked out in the end. To calculate the runs/rises I used a free online program that worked simply and well.
The two side stringers at the deck end of the stairs land over a 4×8 and 2×6 joist; I added a concrete pier under the 2×6 joist at that point for additional support, although the original stairway lasted for 16 years without it, and the deck itself appears to be in good condition. This is in Japan, by the way, where space is at a premium, so I think the height of the risers (216mm = 8.5″) is a bit more than US code would allow, but still not uncomfortable to climb (you should see some of the ladders I’ve climbed in commercial inns (ryokan) where I’ve stayed on occasion.
  1. Hokuto | Aug 20, 2011 11:52pm | #1
    Edit = spam?
    In my original message I inadvertently typed the address to the page of still photos rather than to the slideshow; when I tried to edit the message the forum software said my edit had triggered the spam filter and wouldn't post the message; but the original still seems to be there. Let me try again: here's the slideshow link. The contents are the same, but, whatever.
  2. calvin | Aug 21, 2011 10:00am | #2
    Nice
    and thank you.
    Now, how about turning around and giving us a shot of your surroundings?
  3. Hokuto | Aug 22, 2011 02:29am | #3
    Thanks, Calvin. So what would you like to see in my humble town?
    I also commute to Tokyo, so here's a photo of Tokyo Tower from my office.
    1. calvin | Aug 22, 2011 11:13am | #4
      what would I like to see?
      well, everything I've never seen b/4..........
      or at least what I would see if I leaned over that railing with a beer in my hand.
      and other assorted shots.
      Tokyo at night is one huge beautiful thing!
