My INTEX pool legs are sinking
chriscable | Posted in General Discussion on June 1, 2008 05:53am
I have a 16′ round INTEX pool that has the metal frame around it.  I am having trouble keeping the legs from sinking in the mud.  I have seen some sort of plastic foot that makes a bigger foot print but i don’t know what they are called or where to find them   could someone please help
  1. oldusty | Jun 01, 2008 06:18pm | #1
      Try some pieces of Trex or similar .
           dusty
  2. Hudson Valley Carpenter | Jun 01, 2008 08:24pm | #2
    You're a little late, trying to shore up those posts but let's see what we can come up with.
    I used to install vinyl liner pools each summer, for about six-seven years when work was scarce.  Started out with above grounds and probably installed forty of them over the years.
    I used half a 2" thick concrete patio block, an 8"X8" piece, under each support post.  That's probably too thick a piece to try too get under your posts now so I'd suggest that you buy a sheet of 1/2" pressure treated plywood.
    You can cut pieces to about 6"X 12".   Then jamb them in under the posts, using a heavy hammer to hit another block of wood so as to protect the edge of the plywood.  That should displace the mud and leave you with a better footing for the posts.
    I've never been asked to fix a problem like your's so this is only an educated idea.
    Good luck with it.
    1. chriscable | Jun 01, 2008 10:35pm | #3
      I APPRECIATE THE IDEA I DIDN'T HAVE THE POOL COMPLETLEY FILLED YET WITH MY WORK SCHEDULE IT TAKES A FEW DAYS.    BY THE WAY YOU ANYWHERE AROUND KINGSTON?
      1. Hudson Valley Carpenter | Jun 02, 2008 03:31am | #6
        Not even in NYS at the moment.  Usually in the Mid-Hudson, an hour or so from Kingston.
    Matt | Jun 01, 2008 10:42pm | #4
    Depends on how soft the mud is...
    How about some 4"x8"x16" solid cinder blocks?  And a shovel...
    IMERC | Jun 02, 2008 01:55am | #5
    use cap blocks or those concrete pavers under each leg and on top a bed of gravel....
    WOW!!! What a Ride!
