Mystery Stank…
PaulBinCT | Posted in General Discussion on October 19, 2009 11:24am
Friend called me to come have a look at their house.  They’re moving and until recently had no issues.  But, Murphy’s Law,  they recently discovered a leaking shower neck that broke off creating a small but not insignificant “flood”.  No big deal, virtually no damage but since then they’ve had an unmistakable sewer smell, but not in that same bathroom.  It seems strongest in the bathroom below.  Not IMHO mold that could be attributed to the leak, (and it started almost instantly) but clearly a sewer/waste smell.  I’m thinking coincidence or maybe the flood “activated” a dried up past problem.  Nonetheless they need the smell gone…
I checked for dry traps, the drain line is visible in the basement and looks fine and flushing adjacent toilets doesn’t seem to show any signs of a plugged vent, like the levels dropping. Before I start hacking holes in walls on a snipe hunt, any ideas?
PaulB
www.makeabettertomorrow.com
www.finecontracting.com
  1. reinvent | Oct 19, 2009 11:34pm | #1
    Rent or buy one of these first.
    http://www.amazon.com/s/?ie=UTF8&keywords=rigid+see+snake&tag=googhydr-20&index=aps&hvadid=3503421495&ref=pd_sl_7qxmhcmy9d_e
      PaulBinCT | Oct 19, 2009 11:36pm | #2
      Actually have one... took a look in the wall where the leak originated (forgot to mention that) and didn't see any signs of ongoing mold etc... PaulB
      http://www.makeabettertomorrow.com
      http://www.finecontracting.com
    coonass | Oct 20, 2009 12:43am | #3
    Paul,
    Do a smoke test. Might be surprised.
    KK
      PaulBinCT | Oct 20, 2009 01:34am | #4
      Hmmm, interesting idea but I'm having trouble thinking of how I'd apply it... put a smoke source in the bathroom that had the leak?  What did you have in mind?PaulB
        coonass | Oct 20, 2009 02:15am | #9
        I attach a homemade flex metal pipe/squirrel cage fan to a clean out outside. Smoke bomb is in a metal bucket that I can move away when somebody inside yells smoke! Much fun.KK
          PaulBinCT | Oct 20, 2009 02:24am | #10
          LOL... clever idea, thanks!PaulB
    2. fingers | Oct 20, 2009 02:35am | #11
      What do you use for the "smoke bomb"? Is something commercially available?
        coonass | Oct 20, 2009 03:16am | #12
        fingers,A real plumbing supply house should have them or HVAC supplier.I am hesitant to tell how to make them since I don't like the black helicopters but you can google.KK
        Edited 10/19/2009 8:16 pm by coonass
  3. DanH | Oct 20, 2009 01:42am | #5
    First thing I'd suspect is a bad wax ring on the toilet, especially if the toilet seems to rock at all.
    But if the home has galvanized drain lines there could be a rust-through problem just about anywhere. Check the trap under the sink and make sure the pipe as it goes into the wall is solid and not going soft.
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
  4. DanH | Oct 20, 2009 01:43am | #6
    You could have a situation where past mold (or even a leak of "stuff" that never got cleaned up) was moistened by the water leak.
      PaulBinCT | Oct 20, 2009 01:45am | #8
      Sigh... I hate stank hunting... last time I tangled with a sewer line I had to throw out everything I was wearing from collateral damage :SPaulB
  5. DanH | Oct 20, 2009 01:45am | #7
    Remember, there may be an access panel behind the shower valve. If so, it's worth taking a peek in there. And look under the sink for an access panel -- some older homes have them there.
  6. PatchogPhil | Oct 20, 2009 05:20am | #13
    Re-hydrated a mummified critter in the walls somewhere?
      Luka | Oct 20, 2009 05:36am | #15
      Oh man. Must be a sign.You posted while I was writing...It's all fun and games, until someone puts an eye out..You are always welcome at Quittintime
  7. User avater
    Luka | Oct 20, 2009 05:22am | #14
    Dead/mummified rodent in the wall/floor that got wet ?
  8. nycarpenter | Oct 20, 2009 06:08am | #16
    do a peppermint test down the roof vent- sure to find any rotted lines/open hubs that way. Boil some water and mix the peppermint oil in (get it at the drug store) Have someone else pour it who will stay out side the house while you look for the source. Don't forget to plug the house trap vent!
