Nail Box
| Posted in General Discussion on September 26, 2001 03:42am
I’ve seen these nail boxes, which look galvanized, that roofers wear around their neck on a string. You dump the nails in, and they shaft of the nail drops down slot in the bottom of the box and hangs their because the head is larger than the slot. You can then take two fingers and slide a few nails out from the end and they are in your fingers aligned to be pounded into the shingles. What is the correct name of these boxes, and where can I get one without taking old flashing and making one myself. Thanks.
  1. piffin_ | Sep 25, 2001 10:21pm | #1
    Nail strippers,
    buy at roofing wholesalers.
    try ABC Supply 800-366-2227
    http://www.abcsupply.com/tools/index.html#
    Their website is poor and incomplete
    1. Nanuk_ | Sep 25, 2001 11:46pm | #2
      *PIFFIN - Thanks for the tip, but they don't seem to have anything like that at their web site. If you have any other advice where I can get one, I would appreciate it. Thanks again.
      1. Charles_C. | Sep 26, 2001 05:37am | #3
        *www.rwc.org and look under nail strippers
        1. Luka_ | Sep 26, 2001 08:54am | #4
          *http://www.rwc.org/cgi/catalog.cgi
  2. Nanuk_ | Sep 26, 2001 03:42pm | #5
    I've seen these nail boxes, which look galvanized, that roofers wear around their neck on a string. You dump the nails in, and they shaft of the nail drops down slot in the bottom of the box and hangs their because the head is larger than the slot. You can then take two fingers and slide a few nails out from the end and they are in your fingers aligned to be pounded into the shingles. What is the correct name of these boxes, and where can I get one without taking old flashing and making one myself. Thanks.
Fast, Accurate Wall Framing
