Nail heads vs. fiber cement siding
kuffelcreek | Posted in Construction Techniques on November 24, 2005 11:05am
How do you guys detail the nail heads on fiber cement trim?  The nail heads are hidden on the actual siding, but the hardiplank trim is face-nailed with stainless 8d box nails.  Is it customary to countersink and putty all the heads, or do you just pound them flush and paint over them?
  1. PeteVa | Nov 25, 2005 02:55am | #1
    I shoot clipped heads a bit deep and putty them. I hate nail heads showing, stainless or otherwise.
    1. Dudley | Nov 25, 2005 08:48pm | #5
      PeteVa -- for what it's worth -- you are not supposed to use clipped heads -- I have and have not had a problem -- they must want the whole head as holding power -- if the clipped head is set square, I don't think you will have a difficulty -- my oldest job is 9+ yrs old - Dudley
    2. Framer | Nov 25, 2005 09:00pm | #6
      "I shoot clipped heads a bit deep and putty them. I hate nail heads showing, stainless or otherwise."Pete,It's says this right on the link for nailing, "Do not use aluminum fasteners, staples, or clipped head nails."I've never installed Hari before but I would read everything there is to know about it before I did. Why not follow there installation guide?Joe Carola
      1. PeteVa | Nov 25, 2005 10:46pm | #7
        I'm not arguing with the written instructions. I just know that the few times I've had to remove a piece that needed replacement for size or whatever the 5/4 Harditrim broke before any nails pulled thru or out of the sturcture. If over time the trim degrades then I guess I'll have a problem to address. It's my hope that it does't.
  2. JohnSr | Nov 25, 2005 02:36pm | #2
    James Hardie installation instructions require the nails to be snug against the siding or the trim.  If the nail head penetrates the surface - Hardie requires that the nail head be caulked and an additional nail installed snug to the surface.
    http://www.jameshardie.com/builder/installation/harditrim_installation.php
  3. timkline | Nov 25, 2005 08:11pm | #3
    if you set and putty them, you are going to be in warranty hell with the manufacturers.
    yes, you can see the heads with fibrecement unless you blind nail.
    carpenter in transition
    1. Framer | Nov 25, 2005 08:38pm | #4
      How do you blind nail trim?Joe Carola
      1. timkline | Nov 26, 2005 12:44am | #8
        woops,
        blind nail the siding not the trim
        sorry about that.
        i would consider setting the nails on my own home, but not on a customer's home where the specs must be followed for warranty concerns.
A Practical Perfect Wall
  • The New Old Colonial
