nail size for cabinet trim to ceiling
jah_deetz | Posted in General Discussion on January 3, 2023 01:00pm
Hi all,
I’m closing the gap, about 6 1/2″, between my wall cabinets and the ceiling. I installed 1 by material on the top of the cabinets to which I want to nail a 4″ riser of veneered 3/4″ plywood. To this riser I will then nail 3 1/2″ crown molding which will go to the ceiling. The majority of the crown will have ceiling joists to which it can be attached. Will 18 gauge nails be okay for this setup? Seems a little small but I’d rather not use a 15 gauge if I don’t have. Thanks for your help.
  1. jah_deetz | Jan 03, 2023 04:33pm | #1
    I'm now also wondering if I should install taller blocking on top of the cabinets so that I can support the tops of the risers with nails as well. Not sure if this is overkill or appropriate given the amount of material I'm going to install above the cabinets.
    2sheps | Jan 04, 2023 11:01am | #2
    I would guess the 18 ga nails, if long enough, would be ok. Especially if you use some adhesive.
    Does the cabinet have a recess at the top or is it flush?
  3. max_e_builder | Jan 15, 2023 05:02pm | #3
    18 gauge should be plenty, I'm a finish carpenter and run into similar situations, use a quality adhesive and your should be okay. If you get to installing and it doesn't seem up to your standards try a 16 gauge nailer, smaller hole than a 15 and better holding power than an 18. Good luck!
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
