nail size for crown molding on cabinets
| Posted in Construction Techniques on October 27, 2006 05:18am
I have 15 ga and 18 ga (2″), Would 18 be too thin for cherry crown modling on wall cabinets? I can get a16 ga if it’s perferable.
Should I use glue as well with nails??
Thank you
  1. omnimax | Oct 27, 2006 05:29pm | #1
    I've seen an installer use a 23ga micropinner on prefinished crown.  Couldn't even see the nail holes.  He ripped a 2X4 in half for blocking above the cabinets and nailed to that.
  2. IdahoDon | Oct 27, 2006 10:24pm | #2
    Typically the smaller the fastener the better if it's well supported.  Glue your joints so they'll stay closed and increase the strength of the works.
    If you really want to go with as few nails as possible, a wood backer closely fitted to the crown can be attached first as described above and the crown is glued on with construction adhesive with only the bare minimum of 18 or 23g pins, and/or blue painters tape.
    Typically an 18g by itself is plenty strong for crown.  Keep brads in less visible areas (sunken portions of the profile, knots, easily filled areas) and perhaps even angle two pins into the same hole but going different directions if additional holding power is required.
    Stay away from the portions of the profile that reflect light since these are the hardest to putty well.
    If your cabinets go to the ceiling with the top of the crown in contact with the ceiling a clear paintable caulking can be carefully applied in the joint (essentially none visable on the stained crown) providing a great deal of support for the crown.  It also allows any gaps to be painted the color of the ceiling eliminating the black lines that are so much more obvious.
    Even though it's possible to sand the area under the crown, as well as the portion of crown that actually makes contact with the cabinet and use a wood glue for attachement, sanding finished cabinets is often a bad idea since it's not uncommon for things to be changed and sanding is so very unreversible.
    Best of luck
    1. 30ALL | Oct 27, 2006 10:51pm | #3
      Thank you,  Don.
      installing crown is the most difficult task to me in my diy kitchen, all wall cabinets are up to ceiling in 2". I ordered wall cabinets with extra wide top rails to simplfy crown moldling, hope everything works out fine.
    2. 30ALL | Oct 27, 2006 11:12pm | #4
      I also need to install light rails on the bottom of wall cabinets, use finish nails or screws? the installation I have seen, they all used dry wall screws.
        EricPaulson | Oct 28, 2006 01:36am | #5
        Drill and countersink the screw holes in the light rail in a location that you will determine based on how far forward or back you wish to place it on the cabinet relative to the door and overlay face..
        I use trim head screws, I still have to drill but I can eliminate having to countersink plus they are square drive.
        You could nail it, but it's a bit risky as an errant nail will be sure to pop right through in the most obvious of spots.
        And another vote for the 23ga pinner.
        Bostich makes a decent one for around $100.00
        Eric[email protected]
      2. IdahoDon | Oct 28, 2006 04:07am | #7
        I'd say the choice between nails and screws is mostly dependant on the shape of the undercabinet molding.  Some with a high spring angle make hiding screws difficult.
        Keep in mind that under-cabinet molding is much more likely to get touched, banged, and whatnot, so it needs to be put on well or the corners will open up.
        If at all possible I'd go with trim-head screws and brads, glueing all joints.
    IMERC | Oct 28, 2006 01:44am | #6
    double stick tape and a 23ga pinner...
    WOW!!! What a Ride!
  4. raymond128 | Oct 28, 2006 07:39am | #8
    I have done 2 kitchens now with my porter Cable 23G pinner for crown and other small moldings for the cabinets.Works great. And yes on the gluing of joints and miters.
    I also use an 18G for the under cabinet molding but typically use the pinner for the crown. you can barley even see the nail holes when you done.
    if the crown is of good size I may be more inclined to use the 18G because they have a small head where as the 23G pinner nails have no heads . But if you gve good support to the back of the crown the 23G pinner can't be beat.
    Best of luck.
    Raymond
    PS. I like the porter cable pinner the best!!! It has not let me down once yet.
    Just my opinion
    1. rnsykes | Oct 29, 2006 11:30pm | #9
      I usually cut all of the peices to fit first.  Then glue the corners using that High-Pur hot melt glue with the 60 second cure time.  Then I'll predrill and counter sink the holes through the top of the cabinets and use the screw buttons that come with the cabinets to cover the screw heads.  Has worked well so far.  Before I got the glue system, i used to pinn all the corners, but the less holes in the face of the trim the better.
    PeterJ | Oct 30, 2006 01:10am | #10
    My preference? 23 ga. brads....notice that's brads, not pins. The slight heads do make a difference.  As others have posted, glue your corners. Ridgid and tight corners add significant strength to the assembly. If it's humongous crown, I may use 18 ga., but the more I use 23, the more I trust 'em. I have to remind myself that crown isn't structural, and it doesn't take much to keep it in place.
    On open top cabinets, I sometimes run a bead of Power Grab where crown meets wall to stabilize the assembly.  Also been known to run bead  along crown to cabinet joint to eliminate light from overhead shining through any cracks...that's after install, mind you!  And since we're on the subject of open top cabinets, here's another great idea I saw in client's home.  People put things on top of the cabs...plates, plants, whatever, but they "sink" behind the crown. Seen all sorts of blocks and upside down bowls to jack stuff up near the apparent top of cabinet. Cut pieces of bead foam the appropiate thickness (usually 2-3"), flop it on top of cabs and viola!, a continuous "floor" on whole cabinet top. Makes placing things up there way easier.
    Here's another trick I learned many moons ago. A marker or some stain similar to crown color swiped on the raw miters and/or copes before assembly will get away from "white lines". Do one with and one without to see the difference. The darker the crown, the more white lines show up and look crappy
    Oh, and one other thing. Get some Molding Glue, I think made by Franklin. Goes on more like paste and stays where you put it...no drips...very cool.
    PJ
      Heck | Oct 30, 2006 01:15am | #11
      Good advice. Also wanted to 2nd the trim and moulding glue._______________________________________________________________
      I used to have a handle on life, but it broke
      1. 30ALL | Oct 30, 2006 06:32pm | #12
        thank you all, 1 1/2" finish screws for 3/4"  lights rails that is.
        Used GRK 2 1/2" finish screws and mounting screws, thy are fabulous. No screw head on the frame, and no pre-drill was needed for mounting, and torx screw head never slip.
A Practical Perfect Wall
  • The New Old Colonial
