Nail-Up Bricks???
IronHelix | Posted in General Discussion on August 8, 2009 02:48am
I have been working with a client on a house design and yesterday we discussed exterior finishes, which included brick/stone veneer front elevation and vinyl for the balance.
He then asked if I had seen the bricks that were dry stacked and each nailed to the exterior sheathing. He described a vertical nailing lip on the top of the brick and a small lip on the front bottom edge that locked over the brick in the course below. Much like installing shingles.
He had no brand name, but said he had seen them on a house under construction in the Carolinas.
I have not read about or seen such a product……Can someone help me with a brand name or other information?
Thanks…………Iron Helix
  1. BoJangles | Aug 08, 2009 03:02pm | #1
    NovaBrik.........We've used them occasionally.  A unique product.  Google them.
    http://www.novabrik.com
    Edited 8/8/2009 8:05 am ET by BoJangles
    1. IronHelix | Aug 08, 2009 03:10pm | #2
      What do you know about NovaBrik, have you used it?
      Thanks--------IronHelix
      1. BoJangles | Aug 08, 2009 03:16pm | #3
        Yes, we've used a lot of it.  It's a good product.  Did you look at the website?  What in particular do you want to know?
        BTW...you screw it on, no nails ;)
        1. IronHelix | Aug 08, 2009 05:11pm | #4
          I just got off the web site.
          Plenty of details & specs.
          Great Idea/innovation.
          And a distributor about an hour away!
          I'll get back when I'm more educated.Thanks for your info........Iron Helix
            Huck | Aug 08, 2009 10:08pm | #5
            Skip Crumpecker likes 'em!View Image bakersfieldremodel.com
        2. Piffin | Aug 08, 2009 10:20pm | #6
          are they vinyl?;)
            Dam_inspector | Aug 09, 2009 02:12am | #7
            Is resin the new vinyl?
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
