Nailer for Beaded Paneling?
Flatpicker | Posted in Construction Techniques on October 14, 2005 02:47am
Have a job where I’ll be putting GP beaded 4×8 paneling on the ceiling and one wall of a sunroom/porch.  I’ll be putting up 1×2’s at 12 oc on the ceiling and the wall is covered in 1/2″ OSB.  Will be gluing with liquid nails and nailing.
Question  –  What would be the best nailgun to install the 1×2’s as well as nailing off the panels?  The paneling will be primed and painted.
I have a 15 ga Senco finisher and an 18 ga Senco brad nailer.  But, a friend told me that he put up some of this paneling and the strapping using a pneumatic T-nailer, and that you could hang off the strapping it was so secure.
Should I rent a T-nailer or some other type?  I’d rather not nail it all by hand if possible, but I want it done right.
Thanks.
  1. m2akita | Oct 14, 2005 02:59am | #1
    Ive put up the 4x8 beaded board using construction adhesive and a pneumatic finish stapler ( 18guage).  You can usually pick one up for less than $100.  So far havent heard any complaints.
    -m2akita
    Live by the sword, die by the sword....but choose your sword wisely.
  2. IdahoDon | Oct 14, 2005 03:14am | #2
    Stain grade or paint?   The 1/4" narrow crown stapler is great for most panneling.  With 1-1/2" staples it would even do ok with the 1x2s if you staples them a few times.
  3. Jer | Oct 14, 2005 04:53am | #3
    Ditto on the finish stapler. Give yourself an excuse to pick one up, they're really a great tool.  Once you own one you will use it more than you initially think you will.
    JDRHI | Oct 14, 2005 05:52am | #4
    Framing nailer for the firring strips makes the most sense. Or even a screw gun.
    I might use a siding gun on the plybead though.
    Certainly not one of those finish nailers you mentioned.
    J. D. Reynolds
    Home Improvements
    1. Flatpicker | Oct 14, 2005 03:39pm | #5
      It's a paint grade paneling.
      Would staples show on the surface or have to be puttied in and sanded?
      1. earl06 | Oct 14, 2005 04:06pm | #6
        staple, caulk, paint
        if you're real good, you can staple in the grooves of the beadboard to make it less noticeable.DCS Inc.
        "He who xxxxs nuns will later join the church." -The Clash
