Nailer Gun Advice?
todd | Posted in Tools for Home Building on October 4, 2008 02:13am
DYI here.
I have a Max CN565S siding gun. Shooting 2″ senco stainless steel ring shanks (metal collated)–Hardi Plank siding.
Used about a box of nails so far. My problem is that I’ll shoot a nail (or several)and then blanks…seems that the wire is breaking right at the last nail shot.
On and off problem but chronic now. Think the nails (angle, diameter, etc.) are right. The magazine is adjustable and I’ve got it set to the size of the nails.
The shop that sold me the nails sells and services Max but they don’t work weekends and I’d like to keep banging siding Saturday and Sunday.
Any advice?
TIA, Todd
  1. Danno | Oct 04, 2008 03:21pm | #1
    The guy I work with was having trouble with his nailgun jamming after every couple nails and he found out that the angle of the nails he was using was slightly different than what the gun was supposed to use. Once he started using the nails with the correct angle, he had no more problems. You may want to be certain they are the correct nails. Also, certain brands of nails don't work well in certain guns for whatever (unknown) reason. But I would check the angle first. That is also the most logical (IMO) reason for jams.
    1. todd | Oct 04, 2008 04:34pm | #4
      Thanks, guys.I double checked the nail specs and they are 15 degrees as spec'd. Have a box of ACQ galvanized (senco, too) that I am using for less critical stuff than the SS nails and having the same problem there, too. So I don't think it's a bad batch of nails, but maybe the gun doesn't like Senco. Then again, I bought the nails from a pretty big distributor--they sell and service Max and they handed me the nails without reference...trust they know what they are selling.No problem with gunk on the feeder. Coil is loose, no problem there, either. Guess I'll take it in for service...can't figure it out, frustrating. After this morning's rain it's supposed to be a nice weekend for working outside and winter will be here too soon.
      1. KenHill3 | Oct 04, 2008 07:01pm | #5
        I trust you have the magazine adjusted correctly for the nail length you're using.
        1. todd | Oct 04, 2008 09:45pm | #6
          Yep.
    Sphere | Oct 04, 2008 03:28pm | #2
    I have the same gun, and use Bostitch, Max, and Hitachi nails flawlssly, I think ya got a bum batch of nails. That's all I got, 'cept maybe loosen the coils a bit before ya load em.
    Is the feed paw clean? Sometime when I shoot a lot of DD Galvy's that gets gummy looking.
    http://www.youtube.com/watch?v=Dj_oEx4-Mc4
    The world of people goes up and
    down and people go up and down with
    their world; warriors have no business
    following the ups and downs of their
    fellow men.
  3. dustinf | Oct 04, 2008 03:30pm | #3
    What does the box of nails say?
    Here are the specs for your gun:
    • Features
    • Specs
    • Applications
    • In The Box
    • Accessories
    • 2 Reviews
    Features
    • Patented anti-double fire mechanism
    • Dial adjustment depth control
    • Drives both flat wire welded and plastic sheet collated nails without any adjustment
    • Maintenance free end cap filter
    • Easy twist adjustable exhaust deflector
    • Built-in sound reducer
    • Comfortable rubber grip
    • No-mar contact tip included
    • Lightweight - only 4.9 lbs.
    Specs
    • Nail Length (wire): 1-3/4" - 2-1/2"
    • Nail Length (plastic): 1-1/4" - 2-1/2"
    • Nail Shank Diameter: .092" - .099"
    • Nail Head Diameter: .197" - .236"
    • Collation: 15° Wire or Plastic Sheet
    • Magazine Capacity: 250-400 nails
    • Operating Pressure: 70 - 100psi
    • Air Consumption: .035ft3/cycle @ 90psi
    • Tool Height: 12-9/16"
    • Tool Width: 5-1/8"
    • Tool Length: 10-3/4"
    • Tool Weight: 4.9lbs
    Shipping weight: 11.00 lbs.
    Applications
    • Siding
    • Fencing
    • Exterior Trim
    • Sheathing
    • Subfloors
    • Roof Decking
    • Exterior Deck
    • Furring
    • Strapping
    In The Box
    • Plastic Case
    Accessories
    Pneumatic Accessories
    Air Fittings
    Air Hoses
    Tool Lubricants
    Safety Glasses
    2 Reviews
    Show all reviews | Add a review
    2 Reviews
    Overall Rating: View Image 3.5
    Add a Review
    Reviews
    "the best nailer ever" Submitted on September 3rd, 2008
    Average Rating: 5
    Features
    View Image 5
    Performance
    View Image 5
    Reliability
    View Image 5
    Value
    View Image 5
    Pros: the best nail gun i have ever own
    Cons: none
    Comments:
    2 years in use 5 days a week and no problems at all
    "Bad" Submitted on August 12th, 2008
    Average Rating: 2
    Features
    View Image 1
    Performance
    View Image 2
    Reliability
    View Image 1
    Value
    View Image 4
    Pros: None
    Cons: Various
    Comments:
    Back to Top
    It's not too late, it's never too late.
    artacoma | Oct 04, 2008 11:28pm | #7
    My Max coil gun took a few thousand nails to start operating right ,the nail advance dogs needed extra lube for the first few boxes of nails it my fave right now but had to be broken in, also I always keep it set for one notch longer than the nails i'm using.
    hope this helps
    Rik
  5. m2akita | Oct 05, 2008 02:35am | #8
    Are you able to select on your gun for whether the nails are plastic or wire collated?  The spacing/ feed length may be different for plastic and wire.  On the Bostitch siding gun I have, I have to select for the type of collation.
    Live by the sword, die by the sword....choose your sword wisely.
A Practical Perfect Wall
  • The New Old Colonial
