nailer too cold
chiseler3 | Posted in Tools for Home Building on October 31, 2006 04:58am
Hello’
It is getting cold out there and my nailing equiptment does not want to go.
Every time it gets around 40 degrees the nailer wont fire and the compressor
has a hard time starting and sometimes pops the circuit. If I bring them in
for a while to warm them up they are fine for a while. I tried some thinner oil
in the gun and it did not help. I have a Bostich framing gun and pancake compressor.
John
    IMERC | Oct 31, 2006 05:17am | #1
    lighter oil in the compressor too..
    WOW!!! What a Ride!
  2. Pierre1 | Oct 31, 2006 05:55am | #2
    You might have too much condensation/moisture in your tanks, lines. Even if you drain each day, in cold weather you may want to add a moisture separator to your system.
    mike_guertin | Oct 31, 2006 05:56am | #3
    try pneumatic anti-freeze oil. It's a blend for cold weather. I use it year-round and the O rings seem to last longer - could just be my imagination. Also, I don't take my framing nailers inside in cold weather, it reduces the condensation potential.
    Compressor - is your's an oilless pancake or oil bath? If oilless, try silicone spray in cylinder.
    Luka | Oct 31, 2006 07:20am | #4
    For the compressor, open the drain valve before you start it.
    Let it warm up a bit before you close the valve again.
    Get over it....... The angry going eat you up. ~Brownbagg '06
Picture-Perfect Pergola
