nailing pattern on 1 1/8 plywood
woodlady | Posted in Construction Techniques on August 28, 2006 08:09am
I am going to be installing 1 1/8″ t&g sturdi-floor sanded plywood over 3 1/2″ X 14″ wide I Joists. I have gotten many different answers as to the nailing pattern required. I plan on using Pl adhesive also.Some guys say I should use 3″ screws instead of nails. This will be the finished floor in my new woodshop. Any one want to set me on the right track?
  1. Danno | Aug 28, 2006 02:50pm | #1
    The plywood being T&G and being glued, probably the nails/nailing pattern isn't all that critical. The glue will hold the plywood once it has set--the fasteners in that case are more or less like clamps. 3" screws would be good, if you could do it (maybe can rent one of those screw guns where you stand up, but I've screwed down kitchens of tile backer by just crawling around on my hands and knees and it wasn't bad. If you could rent a framing nail gun (and know how to use it safely) 16d nails would be fine, I'd think--something like a foot apart along the joists. See what others say--this reply would put your posting nearer to the top so more can reply.
  2. mojo | Aug 28, 2006 03:49pm | #2
    I only do a little framing but I think 3" screws are overkill.  The I-Joist flange is 1.5" thick, correct?  So 1.5"+1.125" is less the 3" so your screws will stick out the bottom of the flange unless you hit right in the web.  Just a thought.
    IMERC | Aug 28, 2006 04:03pm | #3
    the glue will do all the work...
    screws is more than ya need..
    3"ring shanks 8"oc and you'll never get it apart...
    WOW!!! What a Ride!
  4. SBerruezo | Aug 29, 2006 08:00am | #4
    I'd probably go with PL Premium and a 6/12 schedule.  If I'm ever in doubt, that's what I go to.  Screws are great, will help reduce squeaks, but it's a lot of time.  I'd likely for 16d or ringshanks--with a framing nailer, I can just fly through.
    Young, poor, and eager to learn
  5. GHR | Aug 29, 2006 09:28am | #5
    The APA website has the correct numbers.
  6. specbuilderli | Aug 30, 2006 01:08am | #6
    has anyone used this instead of two layers of 1/2 inch bc grade?thats what was recommended to me.
      IMERC | Aug 30, 2006 02:09am | #7
      yes...
      works well...
  7. KirkpatrickFramer | Aug 30, 2006 05:21am | #8
    We use 2 1/2" strip screws that work in nail guns. I but them from my nail supplier, I'm sure if you ask around you can find some.
    Just shoot 'em in just like nails, only if you want to pull one out you can use a phillips bit. They work a lot better than the ringshanks. I usually hit 5-7 in each joist. Don't but the 1 1/8" too tight if there's a chance it'll get wet. It has a bad tendency to delaminate. Advantech is much better.
    John
    1. woodlady | Aug 30, 2006 09:06am | #9
      thanks for the info, the local hardware store rents a screwgun for $40 a day that you can stand up and operate.Looks like the way to go. Not to pleased to hear about the plywood delaminating if it gets wet.Hope to get the walls up on the second floor and the roof on before we get our first rains in a month or so.Woking with POLYSTEEL ICF's is fun and fast. I'll keep breaktime posted
