Nailing shoe moulding
| Posted in Construction Techniques on July 1, 2005 04:05am
Should shoe moulding be nailed to the floor? If hand nailing, use 4d’s? Thanks.
  1. calvin | Jul 01, 2005 04:16am | #1
    Hoov,
    If you nail it to the floor and the floor moves, the shoe moves.  Nailed to the base and the floor moves, the shoe stays fitted to the base it was fitted to.
    I'd hate to hand nail shoe, but 4's are ok, 3's will work.
    Quittin' Time
    1. DHoov2 | Jul 01, 2005 04:52am | #3
      Does the type of floor matter? This is 2 3/8" pine, maybe 50 years old.
      1. FastEddie1 | Jul 01, 2005 04:54am | #4
        No, it doesn't matter.  The flooring is held back about 1/2" from the walls to allow for seasonal expansion and contraction.  If you nail to the floor, gaps will appear between the shoe and the wall.
        1. DHoov2 | Jul 01, 2005 05:19am | #6
          On the other hand, if you nail shoe to the baseboard and it shrinks, might you get gap between the shoe and the floor?By the way, would love to get a nailer, but just doing a few rooms after floors are refinished.
      2. calvin | Jul 01, 2005 05:01am | #5
        I don't know, maybe a pine floor would shrink up a bit more than some.  Depending on your location the floor could be swelling up if you've had the hot humid weather of NW Oh.  In the winter, it'll move back.  There are times when you have little choice and then you just throw caution to the wind and fasten to the floor.  I've had situations where the shoe just barely covers the gap at the bottom of the base.  I'd either scab nailers/backers under that base or pop some nails into the floor.  Field decision.
        Quittin' Time
        Edited 6/30/2005 10:05 pm ET by calvin
  2. FastEddie1 | Jul 01, 2005 04:31am | #2
    This is the perfect opportunity for you to buy an 18 ga brad nailer, and use 1" brads to hold the shoe.
  3. piko | Jul 01, 2005 08:38am | #7
    iling shoe over a saltillo tile floor. Nothing is level. the B/bd sits on the high points, w/  up to 1/2" gap under. I used 2" air-nailed brads into the sole plate (they often missed the b/bd anyway).  Sincew it was 1/4 round there really was no chance I'd hit the  b/bd...cove might have been different.
    cheers
    ***I'm a contractor - but I'm trying to go straight!***
    1. mbdyer | Jul 01, 2005 09:56pm | #9
      Why wasn't the base scribed to the floor?  Even a quick rough scribe would at most leave 1/8" gaps.  If I walked away from base with 1/2" gaps I'd be handed a newspaper classifieds to look for a new job.
      1. piko | Jul 02, 2005 04:55am | #10
        I asked the customer which would be her choice - scribe or shoe. She chose the latter. Sure, the gaps are still there,  in some places more than 1/8" (it is saltillo after all, and the tilesetter chose the flatter ones - which were less than 20% of the tiles - for the centre of the room) but scribing would, I feel, accentuate them. In  fact I know...I did a testpiece for her. Scribing looked like h*ll, and the 1/4 round draws the eye and creates shadows. She was very happy with it all - and the only paper I got had my name and some figures on it!
        cheers
        Edited 7/1/2005 10:05 pm ET by piko
  4. mike4244 | Jul 01, 2005 07:26pm | #8
    Toenail with 6d finish nails into the subfloor.This eliminates gaps from either the flooring or base shrinking. This is standard practice whether hand nailing or pneumatic.
    mike
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
