Nailing THROUGH metal straps?
KurtGranrothAZ | Posted in Construction Techniques on March 25, 2020 05:10pm
My structural plan specifies using Simpson metal straps in a few locations.  In all such locations, there will be an OSB sheet eventually covering the strap.  In a few of these cases, the strap falls along a line where it will be necessary to nail the sheathing to secure it to code.  What is the expectation there?
Very specific current example: the engineer specified ST6236 straps centered on the ridge beam connecting the common rafters.  The roof sheathing needs to be attached right up to the top.  Do I nail right through the strap?  If so, are nail guns powerful enough to go through 14 gauge galvanized steel or do I need to pre-drill a hole?  If not nail, then what?
Thanks.
    Mike_Mahan | Mar 25, 2020 05:54pm | #1
    I wouldn't worry to much about the sheathing nails you miss because of the strap. It's only a couple of nails. I've never seen an inspector who would insist on nailing through the strap. The question you should be asking is how you are going to nail a 2" + strap to a 1 1/2" rafter.
  2. KurtGranrothAZ | Mar 25, 2020 07:56pm | #2
    Oof!! The straps were just delivered and you are right -- they are a proud 2" and the nailing holes are all on the outside. This isn't the first time the engineer specified a specific product that physically doesn't work with the other specified bits.
    And thanks for the advice on the rest of the straps. I'll just skip over those.
  3. florida | Mar 26, 2020 01:36pm | #3
    We put the straps on top of the sheathing. Our engineer speced them that way and we can continue working before the inspector comes.
    1. KurtGranrothAZ | Mar 26, 2020 08:31pm | #4
      Oh, thank you for saying that! I zoomed in on the strap detail on my plans and, sure enough, the strap is on the top of the sheathing. I had not noticed that before!
      So with that in mind, I might be able to use the 2" wide strap after all, if I nail at an angle -- taking care of two birds with one stone. Sweet.
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
