Nails for wooden chimney chase metal “top hat”
edwardh1 | Posted in General Discussion on September 10, 2019 06:27am
I have a prefab fireplace and the flue pipe goes inside a wooden 3×6 approx 2 storey high chimney chase , on the side of the house, that has a metal top hat” that the flue pipe goes up under and through. . When it was replaced due to age 5 years ago, I caught the builder guy lying to me, to my face (a whole nother topic)— he said the put eight fasteners all around the 4 sides of the metal top hat. I had watched him doing it, he never moved his ladder, and did not get onto the house roof. I called his boss and he came over and we went on the roof – you could take a yardstick and push up on the top hat– the side that had the 2 screws in it acted like a hinge and the yardstick could lift the whole rest of top hat-
as could a 45 mph wind which would blow the top had off and soak my house and living room side. they fixed it but I dont know how well.
So I thought about that when Dorian went through .
how many fastners do I need and should they be screws or nails and with what size heads, A top hat could easily see 100 to 140 mph wind- seems you would need more than a regular small nail head- that could pull thru the galvalume metal?
what say you Finehomebuilding brain trust- screws? nails? washers? how many on each side? Thanks . would an architcct specify?
now it seems to have 2 nails , together, at end of each side, so 4 nails on the long side, but no fastners anywhere else, that is, none in the middle of the 6 ft long sides. and looks from the ground like 6 penny common nails (small heads.)
__________________
  1. florida | Sep 10, 2019 07:33am | #1
    I would use SS screws rather than nails. No one has ever complained that they had too many fasteners in anything after a hurricane. I'd put 6 on each side and 2 or 3 on each end.
  2. edwardh1 | Sep 11, 2019 11:43am | #2
    and I guess I need the type screws with the washer as part of the head?
    this subject I cant find anything on, on the web.
    if anyone knows where more info might be, please direct me
    thank you
    1. calvin | Oct 11, 2019 08:04am | #4
      Waferhead screws, come in stainless and self drilling through metal.
  3. edwardh1 | Oct 11, 2019 07:45am | #3
    anyone else?
    In florida does Miami Dade have any requirements on this? seems like the hurricane winds would increase the need for more nailing, nails or screws?
A Practical Perfect Wall
  • The New Old Colonial
