Nails Rusting through paint
Sancho | Posted in General Discussion on November 16, 2002 12:00pm
A bud of mine who is a painter told me a client of his had some sideing put on his house. The contractor used regular steel nails. Now the nail heads are rusting through the paint.  He (the HO) dont mind paying to have his home repainted to cover it up when it gets to bad. But does anyone know of a way to correct this .
At Darkworks cut to size made to burn……Putty isnt a option
  1. grantlogan | Nov 16, 2002 12:09am | #1
    Sink 'em and fill the holes or spot prime the heads with a rust inhibitive primer.
  2. MarkH128 | Nov 16, 2002 03:22am | #2
    Some people like to use aluminum paint to prime the rusty nailheads, but I don't know if it is better than a rust inhibitive primer. But do make sure that the primer is not latex.
    1. Sancho | Nov 16, 2002 04:22am | #3
      Thanks guys Ill pass it on to him.
      At Darkworks cut to size made to burn......Putty isnt a option
      1. 4Lorn1 | Nov 16, 2002 12:55pm | #4
        Somewhere I heard that the problem won't return if you use auto body putty over the countersunk nails. I do know that the stuff doesn't shrink when it dries so it might also save you a step.
  3. villagehandyman | Nov 16, 2002 08:21pm | #5
    the rust started before the paint was applied how long did the job sit before painting
    you will need to hit each nail with rust preventing primer like kilz galvanized nails would not have helped
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
