Nails vs. Staples Cedar siding
jayri | Posted in Construction Techniques on December 2, 2005 02:35am
Any thoughts on using staples to fasten red cedar shingles vs. using ring shank coil nails?
Been using Nails for years but just met up with a sub who swears by the staples.
Also any thoghts on Galvinized versus stainless fastners on red cedar shingles that will stay natural when nailing above the weather line?
Thanks,
Jay
  1. zendo | Dec 02, 2005 02:52pm | #1
    Ive seen some real messes with the staples.
    If wind is an issue I would say no deal.
    Production guys like them because they are fast and cheap, and the guns are light.
    -zen
  2. Bruce | Dec 02, 2005 03:32pm | #2
    Did several cedar exteriors as a trim sub to a contractor who wanted to try using divergent point staples, meaning the "chisel" points on the legs of the staples are cut in opposite directions.  As they enter the material, one leg goes north and one goes south, so to speak.  You cannot pull them out.  I suppose there's still a chance that the cedar could pull off of the staple, making nail heads more secure, but it hasn't happened on these homes.
    Personally, I would stick with hand driving ring shanks, unless you could show me a gun nail that has that nice little head, and a dull fuinish, and will set just flush.
    Bruce
    Between the mountains and the desert ...
    1. averagejoe | Dec 02, 2005 04:45pm | #3
      Sure, theoretically nails may be "better", but only in the same way a 2 x 10 header is "stronger" than a 2 x 6 header when installed over a 2' wide window in a non load bearing wall. A couple of years ago I did my first shingle siding job on my own house. I already had a narrow crown stapler and I was curious about the same question, so I nailed some shingles using both hand driven nails and galv. narrow crown staples into some 1/2" ply. Using either method I destroyed the shingle trying to pry them off, and after clearing away the scraps of wood left stuck around the fasteners, each seemed to require the same amount of effort to remove with a small cats paw.So I went with the staples (1 1/4" galv., prestained white cedar fastened above the overlap, 5 1/2" exp.) Every so often I had to remove a shingle or two due to a screw up, and the difficulty of this excercise removed any doubts I might have had about the holding power of staples.
  3. Demon | Dec 02, 2005 07:10pm | #4
    I always use stainless in exposed situations, galvanized can stain the shingles. I have used both staples and ring shanks, I don't think there is much difference between the two. I use my Bostich fence/siding nailer usually, set to flush or just proud. It's cake to finish off with a finish hammer if the nail is protruding slightly. My .02.
    1. Bruce | Dec 02, 2005 07:54pm | #5
      I agree w/ stainless to prevent staining, but can you get them with a dull gray finish? I hate that little shiny spot.Bruce
    2. Waters | Dec 02, 2005 09:43pm | #6
      what model is that bostitch fence/siding nailer you mention?  I think I want one of these...
      Thanks,
      Pat
      1. Greg | Dec 02, 2005 11:22pm | #7
        Bostich N66C-1 Siding and Fencing Nailer
        http://www.amazon.com/exec/obidos/tg/detail/-/B0006FKI5G/sr=1-2/qid=1133554755/ref=sr_1_2/002-6475005-0451252?%5Fencoding=UTF8&v=glance
        Hitachi NV65AH Siding Nailer
        http://www.amazon.com/exec/obidos/tg/detail/-/B0000225JZ/sr=1-1/qid=1133554755/ref=sr_1_1/002-6475005-0451252?%5Fencoding=UTF8&v=glance
        I haven't tried the Bostich, but really love my Hitachi.
        Greg
         The older I get, the better I was....
        1. Demon | Dec 03, 2005 01:17am | #8
          Yep, that's the one. Those coils do alot of shingles, too, before needing a reload. The tip is adjustable so you don't have to fiddle around with the air pressure. Don't ask me how I know this, but if you forget to turn the compressor back on, it'll shoot consistently till the pressure drops to a point that the gun just won't fire.
          1. Greg | Dec 03, 2005 03:02am | #9
            I have the Hitachi.... uh... somebody... yeah ... somebody told me that it will run without a compressor too.
            Don't remember who, any more... The older I get, the better I was....
          2. Waters | Dec 03, 2005 06:30am | #10
            Thank you Greg.
            "uh... somebody... yeah ... somebody told me that it will run without a compressor too.
            The older I get, the better I was...."
            You must have "CRS."  New discovery in neurological disorders...
            "Cant remember ####."
            Cheers,
            Pat
          3. Lateapex911 | Dec 03, 2005 07:33am | #11
            Another vote for the green gun...
            I am confused though.....why will the nails be visible? Mine were always tucked up under the next course.
            is it a situation where the exposure is greater than the appropriate nailing "span", and the nails have to be visible? All the ones I have used have been "bright", but some have had a waffle head, which dullls them.
            And I am another stainless only user.Jake Gulick
            [email protected]
            CarriageHouse Design
            Black Rock, CT
          4. Demon | Dec 03, 2005 03:29pm | #12
            How do you get a course under the window sill?
          5. Greg | Dec 03, 2005 06:00pm | #14
            Pat -
            To be honest, I've had CRS for longer than I can remember.
            Then again, I probably needed to forget some of it.
          6. Waters | Dec 03, 2005 10:29pm | #15
            So you have "early onset" CRS...
            I have this too, at 35 yrs of age..
            Cheers,
            pat
  4. andybuildz | Dec 03, 2005 04:57pm | #13
    What everyone else said but: you can use galvie nails. You can use dbl dipped ring shank. Stainless steel as has already been said is for exposed nails and the dbl dipped galvies are for nails that are covered by the proceeding courses.
    I found the MAX nail gun awesome!! I did the entire wood roof and walls with them . I ended up buying three of those guns for this house. One for each one of my guys to use. I'll be selling one soon if youre interested. I have no need for three anymore and I only used it on this house.
    Be gettin nailed!!
    andy
    When we meet, we say, Namaste'..it means..I honor the place in you where the entire universe resides, I honor the place in you of love, of light, of truth, of peace. I honor the place within you where if you are in that place in you and I am in that place in me, there is only one of us.
