NEC/Wall receptacle next to fireplace
Viewtown | Posted in General Discussion on January 24, 2009 10:29am
I want to install a wall receptacle next to my fireplace. I’ve checked the NEC and can’t find if there is a minimum distance for installing a receptacle next to a fireplace. I’m aware of the minimum distance for combustible material, but not a wall receptacle. Any suggestions/guidance is appreciated. Thanks.
    BillHartmann | Jan 24, 2009 11:50pm | #1
    There is nothing in the NEC.
    How close do you want it?
    1. Viewtown | Jan 25, 2009 12:19am | #2
      From the left side fireplace opening about 18" or so. The plan is to use the receptacle for the wood stove fan.
        BillHartmann | Jan 25, 2009 12:57am | #3
        That should be plenty of distance.You can get into derating and some other things if you are in a "hot" area.But that is far enough away..
Fast, Accurate Wall Framing
