Need a big Shaper cutter.
Need a 1-3/4″ Shaper cutter. (1-3/4″x1-3/4″) Any body know a source that makes them as a stock size? I checked out CMT, Amanda and a few others on line but they were too small. My guess is a custom cutter would run $400–. Thanks.
Best to you and yours, Chris.
Some say I know too much.
Charles C G Schmidt in NYC has a good selection od stock cutters in various bores.
LRH also has a bunch.
Freud has - or used to - a wide selection, but all metric sizing other than the bores.
They are all online in one form or another. Some of the stock cutters will cost $400, though.
Dave S
Thanks Dave,
I tried Freud. Turned out that their site was easy to navigate but no luck. Charles C G Schmidt wasn't in Googles purview.
Anyone else?Best to you and yours, Chris.
Ballew will make just about anything you want, any size you want, any number of cutters you want . . .
http://ballewtools.com/
Get a free catalog. It'll ruin your checkbook.
Real trucks dont have sparkplugs
Cool! I'll give it a try.Best to you and yours, Chris.
Thanks! Found it! Made by Freeborn Tool.Best to you and yours, Chris.
I've found Freeborn cutters to be excellent. Any question, call, they'll have an answer.PAHS Designer/Builder- Bury it!
Are you in southwest MO? How is their catalog operation? Always knew they had it but never bothered to use it, I just walk in and grab a seat at the counter. These guys have come through for me with custom moulder knives more than a few times and their sharpening service is second to none. This place is a top notch family operation.
Most large sharpening services have an in house cutter department. Try going local first.
As previosly posted, ballew carries quite a bit of Freeborn and King Cutter. Freeborn is a better choice than King cutter in price, king cutter has a better 'stock" selection. If you are going to use these cutters on in sloid wood, no mdf/particle board/plywood, then spend the little extra and go with the Tangtung(yellow) cutter from Freeborn.There regular carbide(orange) cutters are great too.
Maybe show a profile that you need in the quantilty and material required and you may get some better info.
http://www.lrhent.com/
They are of excellent quality
Thanks for the needle in the hay stack link.
They are of excellent qualityBest to you and yours, Chris.
