Need advice on cutting concrete basem…
| Posted in General Discussion on January 22, 2001 05:17am
Hi-
I need to make a 10-12 foot long cut through my concrete basement floor, about 4″ wide to add a pipe for a floor drain on the other side of the basement. What tools work best for doing this? I would like to stay away from a big gas powered cutting machine. Should I use a small cuttoff tool with a diamond blade, a jackhammer, etc? Your opinion from EXPERIENCE I would much appreciate.
Thanks-
Brian
  1. BrianGale | Jan 22, 2001 05:17am | #1
    Hi-
    I need to make a 10-12 foot long cut through my concrete basement floor, about 4" wide to add a pipe for a floor drain on the other side of the basement. What tools work best for doing this? I would like to stay away from a big gas powered cutting machine. Should I use a small cuttoff tool with a diamond blade, a jackhammer, etc? Your opinion from EXPERIENCE I would much appreciate.
    Thanks-
    Brian
Old House Air-Sealing Basics
