Need advice on spraying SW pro classic oil in my Graco 4900 procomp
trimdaddy | Posted in Construction Techniques on May 7, 2010 08:36am
I have a job in which I am building some columns, beams, bookcases, and am adding some moldings to the existing fireplace.  The bookcase is being finished with a pigmented CV. I want to finish the rest of the stuff using the same paint used to paint the rest of the existing trim.  It was finished with SW pro classic oil.  I have a Graco 4 stage turbine. I have only ever sprayed lacquer in it .  I am looking for some advice for as to which tip to use and how much to thin the paint in order to get a nice finish. Also should I use a paint additive like penetrol?   Also what is the best/easiest primer to use with this setup?
  1. rlrefalo | May 10, 2010 08:31pm | #1
    One thing I can tell you is do not use penetrol on any light colors. It WILL make it yellow  quickly.
