NEED AN EXTERIOR ADHESIVE
| Posted in General Discussion on August 11, 1999 05:30am
I am looking for an exterior adhesive or glue to use on my pre-primed (“Cabot’s” oil based) casing material for an outdoor installation of custom pediment & crosshead build-ups. I need to glue two primed surfaces together and have that joint not fail in these New England weather conditions. I have tried “Phenoseal”, “Tite Bond”, “Gorilla Glue” and other related manufacturer’s products. Using my not-very scientific testing and sampling methods, I haven’t found anything, that I feel, will hold up in time.
Whenever I try to get a recommendation from a manufacturer or someone of experience, I’m just led down another dead end path.
Is there a “a guru of glue” out there somewhere that can be of help????
  1. bullet | Aug 10, 1999 08:35pm | #1
    construction adhesive--it's waterproof and flexible and will stick to damn near anything.
  2. Guest_ | Aug 10, 1999 09:12pm | #2
    Gorilla Glue should work. It is important that the pieces be moistened before they are mated together. I'm not a glue guru but I suspect the weak point in the glue bond is the paint film itself. Bare wood should give better bonding results.
  3. Jim_T. | Aug 11, 1999 12:16am | #3
    I've used both gorilla glue and Weldwood Resorcinol adhesive. Both have worked fine in my exterior applications. I prefer the resorcinol glue since the gorilla foams when it polymerizes.
    I agree with Jcallahan-you may want to sand/plane the primer off before application.
  4. Guest_ | Aug 11, 1999 05:24am | #4
    jcallahan and Jim T. have both given you all the advice you need. Lose the paint and glue the bare wood. Paint just makes a barrier for the bonding of the wood.
    Ed. Williams
    1. Guest_ | Aug 11, 1999 05:30am | #6
      *One more vote: from experience, any finish on the wood ruins the bond. Sand it off.
  5. TL | Aug 11, 1999 05:30am | #5
    I am looking for an exterior adhesive or glue to use on my pre-primed ("Cabot's" oil based) casing material for an outdoor installation of custom pediment & crosshead build-ups. I need to glue two primed surfaces together and have that joint not fail in these New England weather conditions. I have tried "Phenoseal", "Tite Bond", "Gorilla Glue" and other related manufacturer's products. Using my not-very scientific testing and sampling methods, I haven't found anything, that I feel, will hold up in time.
    Whenever I try to get a recommendation from a manufacturer or someone of experience, I'm just led down another dead end path.
    Is there a "a guru of glue" out there somewhere that can be of help????
Picture-Perfect Pergola
