Need Fix for Stripped Metal Switch Box Screw Tab
BillAllemon | Posted in Energy, Heating & Insulation on January 10, 2016 04:29am
I have a 1948 construction home with fairly heavy metal junction boxes. One of the lighting switch boxes has a stripped tab where the electrical switch mounts to the box. I believe the screw is a standard 6-32. I don’t want to replace the box, because of damaging the wall finish, etc. Is there a larger self-tapping screw that I could use to mount a new switch to this box? I thought of using a small bolt with a nut, but that would be a bit difficult to accomplish. I thought going with a larger self-tapping screw would be better, but not sure what to use. I’d appreciate any thoughts.
    coonass | Jan 10, 2016 05:01pm | #1
    tap
    Tap it to 8-32
    http://www.amazon.com/Klein-Tools-627-20-Six-In-1-Tapping/dp/B000H6X69Y
    KK
    1. BillAllemon | Jan 11, 2016 06:38pm | #5
      Thanks!
      Thanks for the quick reply and simple solution. And the product link. With an old house, this will come in handy.
  2. DanH | Jan 10, 2016 05:07pm | #2
    I had a situation with a lamp box where the strap across it had a screw hole that was stripped, so the lamp couldn't be mounted.  In that case I removed the strap and "formed" the metal (pounded it with a hammer) to close up the hole, then re-tapped it.  (This fix was assisted by the fact that the screw hole was in a "dimple" that could easily be pounded flat, but the same fix would work for a flat strap, you'd just need to pound it with, eg, the round end of a ball peen hammer to smush the metal together.)
    If the piece holding the hole can't be removed, I'd first look at "repurposing" one of the spring metal "nuts" from a modern box.  Even if the piece would not fit over the edge of the box you could perhaps tape or glue it in place behind the flange.
  3. jimmiem | Jan 10, 2016 07:56pm | #3
    Electrical Box
    Larger Self Tapping Screw or Fender nut.  Self Tapping Screw probably the quickest.
  4. Norman | Jan 11, 2016 05:33pm | #4
    +1 for simply tapping it out to 8-32. If it is REALLY stripped, you probably won't even have to drill a hole.
    Good luck.
  5. renosteinke | Jan 16, 2016 10:53am | #6
    Triple Tap Tool
    I start using the 'triple tap' tool- a screwdriver whose bit is threaded with three (progressively larger) thread forms. The usual version is made foe 6-32, 8-32, and 10-32 - all common in electrical work.
    Just cleaning the damaged threads with the 6-32 tap often gives you enough thread for the original screws to bite. Otherwise, it's no problem to simply continue running the 8-32 tap into the hole.
    The only downside to using 8-32 screws is that the heads look different.
    Several have suggested 'self threading' screws. Please note these are NOT the screws with little drill tips, or sharp points, on them. It's a trade practice to avoid putting anything 'sharp' inside a box with wires in it.
    Box hole threads are most often damaged when some handyman can't be bothered to use the right screw, and instead substitutes a drywall, sheet metal, or other screw in place.
