Need for an underlayment on metal shed roof
esteeste | Posted in General Discussion on August 25, 2019 09:58pm
I’m a longtime lurker of this forum. I’m building a simple 10×12 gable shed here in rainy Seattle area. Roof pitch is 10:12. It has 12×12 inch gable vents at both ends. The shed will be unconditioned/no insulation. Was planning on 1×4 skip sheathing with a metal roof to match our house and no waterproof or water resistant barrier. A contractor friend noted that metal roofs can often have condensation form on the underside when the inside temp is warmer than the outside (e.g. early evening on what was a hot, humid summer day). I’ve heard and read different opinions on this, but I trust the advice on this forum more than others. It’s just a shed, but I want to do it right and not have water issues so I’m thinking the waterproof/water resistant barrier would be wise.  What would you all recommend? And if you recommend a barrier of some kind, should it be waterproof or water resistant? (I’ve heard that Grace Tri Flex is good…) Many thanks.
  1. Graceconstruction | Aug 26, 2019 06:51am | #1
    We use any kind of synthetic paper run perpendicular to the purlins. It’s enough to keep the condensation at bay. A better option is to sheath with plywood and run the paper perpendicular to the metal sheets. It’s a better install and usually cheaper than skip sheathing.
  2. florida | Aug 26, 2019 08:41am | #2
    I would install Zip sheathing, tape the seams and never worry about it again.
Deck Details for Durability
Freestanding with boxed stairs, this small deck is full of ideas for a long-lasting entry that will look great for years to come.
