Need heating options
gh2 | Posted in Energy, Heating & Insulation on December 23, 2010 03:29am
I have a 100 yr old home in northern NJ that has a two level enclosed porch.  Last summer I renovated the first floor by removing the wall coverings (stucco) and insulated, sheetrocked the walls.  In this space there was a through the wall gas heater which was working until I finished the renovation and it no longer works.  The unit is too big and I was looking to remove it and replace it with something more pleasing to the eye.  Are there any low profile ( eg toe kick heaters, in wall heater or ceiling heater) that I can replace this heater with?  I’m open to high effiency electric units but I’m afraid of the monthly electric usage charges.  BTW, the second floor will be converted to a bedroom.  Both spaces are 160 Sq FT each.
    MarkH | Dec 23, 2010 05:10pm | #1
    Look at Empire DV-210-SG
    Look at Empire DV-210 heaters, see if that would be suitable.
  2. DanH | Dec 24, 2010 09:26am | #2
    There are a bunch of options.  Heat may be able to be gotten from the heating plant for the rest of the house, but lots of variables there.  (Keep in mind, eg, that a hot air register currently on the outside wall abutting the porch could be extended under the floor to the new outside wall.)  Beyond that there are a number of "wall furnaces" that would burn gas and be reasonably efficient.  Electric resistance is the cheapest/easiest to install but most expensive to operate.  (All electric resistance is equally efficient/expensive to operate.)  A motel-style heat pump unit be more efficient than resistance, and probably a good compromise if a gas wall furnace doesn't work out.
    There are also options with hydronic heating, possibly making use of your existing water heater, if you don't have hydronic in the rest of the house.
Mortar for Old Masonry
