Trying to cope a fairly simple profile. Cut with a miter saw, trim with a dremel and files. But no matter how hard I work at it, I just can’t get that danged outside corner to cope properly. What am I doing wrong?
“Put your creed in your deed.” Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.” T. Roosevelt
Do a search on coping with a mini grinder
On a hill by the harbour
I still like using a coping saw to cut. I do have to highlight the cut line by rubbing a pencil right at the cut angle, so I can see it with my old eyes.
I back cut the profile a little bit, so it has some room if the corner isn't a perfect 90.
I've tried using a Dremel, but never got far with it. I've always found it faster coping most mouldings with hand tools.
I trying to cope here, myself.
Whoopsie...I meant the other kind...oh, geez,
never mind...
(bump)
Well, the sun rose... in so many colours it nearly broke my heart... Worked me over like a work of art...and I'm all part of that...
<I just can't get that danged outside corner to cope properly.>
outside corner?
are you pulling someone's leg?
That's what I was thinking.
next he's going to tell us he heat treats babbit bearings. <g>
Barry E-Remodeler
Are you cutting on a 45? If so, how are you setting the molding on the fence?
(No, it isn't a stupid question)
Edit: give us a break man, its getting late.
Edited 12/8/2008 9:16 pm ET by arcflash
Outside corner is your problem!
Hey Fast Eddie....you pullin' a fast one on us?
Outside corners....(slapping knee)
45 deg. is for inside corners. For outside corners you need a 135 deg. miter.
See my work at TedsCarpentry.com
Buy Cheap Tools! BuildersTools.net
If you haven't already done so, please update your profile. Since many issues are dependant on the region in which you work, we often look at your profile to see where you are writing from.
Wow, thanks Ted, that's the problem: my miter saw doesn't have 135* on the scale. Need to ask Santa for a new saw. What model swings that far?"Put your creed in your deed." Emerson
You need the Acme 360 Tri-bevel glider. The slider would work, but for that kind of money you may as well get the glider. For that matter, why not splurg and get the Z-axis rotating model.
Hope that helpsSee my work at TedsCarpentry.comBuy Cheap Tools! BuildersTools.net
Is that sold at Harbor Freight?"Put your creed in your deed." Emerson
You'll need it to swing both ways. You might ask Rez or IMERC what they use.
Clamp a speed square to the fence, away from the blade. You can now cut damm near any angle you want..I've made a wooden one just for that reason. It'll let you make a LONG thin cut for a scarf..if yer into wearing a scarf..of wood, thats pointy.Spheramid Enterprises Architectural Woodworks
I've never coped an OUTSIDE corner. Just 45* or there abouts.
Could be you are coping something that should not be coped !!! Do you mean inside corner???
Ok guys, it was a joke. Just wanted to see how long it would take someone to pick up on it. I actually was coping some joints yesterday, most came out good, one is excellent, one should be redone, and my mind just started wandering ...."Put your creed in your deed." Emerson
Well, ya got me LOL
Ed, I take it this is your attempt to get a handle on the new names here.
or you been hitting the bottle a tad much.
http://www.quittintime.com/
