Need Help..Custom Shower Pan for Base…
| Posted in General Discussion on February 18, 2001 09:56am
I am putting in a Shower in the basement and the drain location is such that standard shower pans will not work.
Is there a source for a custom made pan or does anyone have ideas on how to make my own ?
  1. Ron_Rosa | Feb 12, 2001 06:28am | #1
    I have heard of a number of products used for custom pans such as epdm roofing,fiber glass,and polar systems roofing.
    1. Ralph_Wicklund | Feb 12, 2001 06:38am | #2
      *??What is it, specifically, about the drain location that precludes the use of standard shower pans?
      1. Tim_Kline | Feb 14, 2001 06:32am | #3
        *b WBA At Your ServiceSteve, Check out or make your own with shower pan liner material available from your local professional tile supplier. One trade name is chloralloy.
        1. Grant_Logan | Feb 18, 2001 02:45am | #4
          *I have fabricated several custom pans from copper. Any decent sheet metal shop should be able to do the job.
          1. Daniel_Casey | Feb 18, 2001 07:57am | #5
            *Taunton's Setting Tile book is a good source.I used it to help with the shower in our new house.But, after watching the TileRedi video, I did it the conventional way, I would go with TileRedi.The only problem I see is that it's offered in a limited number of sizes, so this may not fit your application.
          2. John_Lazaro | Feb 18, 2001 09:56pm | #6
            *If you like solid surface materials, you can try your local Man-made marble suppliers, countertop manufacturers, even my Jetta tub dealer makes them.Good Luck,John
  2. Steve_Hughes | Feb 18, 2001 09:56pm | #7
