Need help planning a fuel tank installation
Quickstep | Posted in General Discussion on November 8, 2010 11:03am
I’m planning for the installaiton of a fuel tak for home heating oil. I have a location picked out near an exterior wall. Because the tank is basically tight to the wall, there’s not enough room to us 45s to make the turns. Is it OK to uise 90s as shown in the attached drawing? Also, is there a minimum distance the tank must be from the furnace?
  1. Piffin | Nov 08, 2010 07:59pm | #1
    Every one I have ever seen used 90° elbows
    Distance to boiler or furnace - I am sure there must be some limitations based on the fact that flow is reduced by friction, but that can be overcome by larger diam supply pipe.
    I have seen several that have a run of 40-60 feet with a 3/8" copper line
    It does help if the tank is higher than the end use point. No sense in fighting gravity
