Need help with ADA Code
| Posted in General Discussion on May 27, 2001 01:24am
I am building a commercial building ( my woodshop) and need to meet ADA Code (handicap) Specs. The question I have is regarding parking space and sidewalk. Does the parking space need to be paved? I have heard yes and no from different architects. If yes, will oil & chip do vs. blacktop or concrete? How wide does he space need to be?
Thanks for your help.
By the way, check out http://userweb.nni.com/[email protected] for progress on the building.
-Randy
  1. kkearney | May 21, 2001 04:10am | #1
    Randy,
    Go to http://www.access-board.gov/adaag/html/adaag.htm
    KK
    1. Trent_Baughn | May 21, 2001 02:57pm | #2
      *Randy,12'min; 13' max (assuming a perpendicular space).Regarding the surface..."it shall be stable, firm, slip-resistant..." How's that for vague!
      1. Rich_ | May 27, 2001 01:24am | #3
        *As Trent pointed out the ADA is open to interpretation. That interpretation usually is handed down from the local planning dept which is usually represented by a single individual. This means that one individual has enormous power and influence in how your job progresses. Also, this interpretation may change on a job-to-job basis.The ADA is "vaguely written, strictly enforced".
  2. Randy_Stukenberg | May 27, 2001 01:24am | #4
    -Randy
FHB Podcast Segment: Patching Drywall Near a Shower
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
