Need help with cutting vinyl J channe…
| Posted in General Discussion on July 15, 2001 03:05am
We are installing vinyl beaded ceiling panels.
Right now I am trying to put up J-channels around the perimeter and and going around flush mounted ceiling lights and also support posts.
No problem cutting the “trick” miters for the inside corners.
I need help on the puzzle of cutting these miters for outside corners.
I did cut one successfully but there must be a fast rule for cutting these corner miters…..
Certainteed’s diagram in their PDF file isn’t very informative.
I would appreciate your help if you know of a site with good diagrams.
Thanks !
Alan
  1. Alan_Kim | Jul 15, 2001 03:05am | #1
    No problem cutting the "trick" miters for the inside corners.
    I did cut one successfully but there must be a fast rule for cutting these corner miters.....
    Certainteed's diagram in their PDF file isn't very informative.
    Thanks !
    Alan
Grout-Free Shower Panels
